-   -   Really powerful cold engine, warm not so fun.. :-/ (https://www.xedos-community.de/showthread.php?t=47682)
aw_309 28.05.2015 08:29
Any ideas? Redoes 6 v6 1995
1 When I'm driving it in the morning the car feels really good and response fast.
When the engine is warm and after a while it feels slow and weak.. :-/
2 Also I'm thinking about getting an open airfilter to the car. Is it any special i should have?
3 Is it possible to use any chip to the car. ?
Loading 29.05.2015 22:29
Any error codes?
Maybe the knocksensor is going to die....
aw_309 30.05.2015 13:14
Why do you think its this nocksensor?
Loading 30.05.2015 15:25
because if the knock sensor is broken ur engine has no power.....
but if he is really broken there must be an error code in your system....
neo303 31.05.2015 15:22
don't do that - you will lose power. the air intake is part of the VRIS-system and has been well designed by the engineers.
yes, it's possible. but what for? unless you have a turbo charger, changing the software won't give you more power. better spend the money on new spark plugs, spark plug cables etc.
cheers
aw_309 02.06.2015 06:59
I only have one faultycode 41 vris solenoid ( 4 short - paus - 1 )
Ive had this before and it was the connection.
Also i noticed when im driving with half gasoline tank it behaves like it doesnt get enough gasoline. Maby the filter inside the tank??
It feels sometimes lite the car only sound powerful but the speed is not the same. Often when its warm. I want to feel that punch when you hit the gaspedal even in slow speed.
Its a automatic gearbox!
Ive changed the oil! :)
Mazda RX-7 SA 02.06.2015 11:53
Have you checked if the VRIS valves are working when the car/engine is warm?
aw_309 14.06.2015 08:36
Fuelpump
I fixed the vris 1!
But still problem with this slow reaktion and when I'm hitting the gaspedal its a quick stuttering.
I have all this time problem with a half gas tank and less that it stutter and feels weird so is it the fuel pump maby?
Is it easy to exchange? inside the car?
S1PikesPeak 14.06.2015 11:09
Zitat von aw_309 (Beitrag 140631)
I fixed the vris 1!
You really should check the Fuel Pump.
Mazda RX-7 SA 15.06.2015 11:16
Yes, by messuring the fuel pressure in the rail.
Should be around 3-3,5 bar.
Alle Zeitangaben in WEZ +1. Es ist jetzt 22:29 Uhr.
