Alt 07.05.2016, 12:53   #1
aw_309
Vaccum problem help please!
I have a sound like pssssssssssss near ther throttle house.
Also the idle goes up and down.
Any idea? Cant fint the leak or what it is.
Thanks!!
Alt 07.05.2016, 21:48   #2
jarek9
Benutzerbild von jarek9
XEDOS 6 ,V6 170 tkm-144ps 1992-RIP
Xedos6 V6 290 Tkm Bj 1998 & Xedos V6 140Tkm 98Bj
Bypass adjustment screw from Throttle body?
jarek9 ist offline   Mit Zitat antworten
Alt 13.05.2016, 14:56   #3
aw_309
Hello!
It was an air host under the throttle house but now i have mooooore problems.
I have no luck with this car, still i love it!
so I have a new rubber host to the throttle house and the vris works perfect BUT
now I have strange behavier when i´m hiting the gas pedal the engine is very slow and sometimes i put the gaspedal all the way down and its not reacting much, only around 3000 rpm not more.
It sometimes dies when the rpm goes down to much. I have a little leak on the exhaust system in the back but that could not do so much problem like this??
Geändert von aw_309 (13.05.2016 um 16:00 Uhr)
Alt 15.05.2016, 10:09   #4
Have you replaced all vacuum hoses by new ones?
Because especially when you changed the engine and reused old hoses they can leak....
Alt 16.05.2016, 13:54   #5
aw_309
No but they are fine.
Have used startgas all over the engine without any reaction.
Alt 16.05.2016, 14:31   #6
This method is good to find leakages in intake system. But not in the vacuum control system.
How you are sure?
I recommend again, to replace all vaccum hoses. Just because of the age!
Alt 17.05.2016, 09:00   #7
aw_309
I also have a misfire around 1300rpm as most.
Could it be the ignition coil?
Alt 17.05.2016, 16:22   #8
hörnchenmeister
Check the ignition cables and plugs. If they are oiled the ignition can fail.
Alt 17.05.2016, 17:38   #9
aw_309
I will do that but its strange!
No faultycode.
If i do kickdown the car will rev good but after it loses the power
And in will only go upp to 2500-3000rpm and sound strange " blrrrrrrrrr" not wrauum.
Also it smeels like it desnt get the correct mixturr with air and petrol.
