Alt 18.06.2010, 14:48   #11
Artemmka
Benutzerbild von Artemmka
Sieht man doch sofort an der Ansaugbrücke
What do you mean?
Was meinst du?
Mit freundlichen Grüßen,
Artem (рус.Артём)
Alt 18.06.2010, 16:48   #12
Eddyk
Die Ansaugbrücke ist, außer beim Xedos 9, bei den KL runder als bei den KF.
Alt 18.06.2010, 17:34   #13
Und irgendwie fluchten die Anschlüsse an Drosselklappe und Luftmengenmesser nicht.
Wird der Lebensdauer des Zieharmonikaschlauches nicht zuträglich sein.
(Eingangspost Bild 2)
Alt 19.06.2010, 20:57   #14
Artemmka
I have air flow meter KL05. I put it in Xedos airfilter box.
Also i drive on KL05 ECU
Artem (рус.Артём)
Alt 20.06.2010, 12:27   #15
shane
so, very welcome Artemmka! i hope you find a lot of useful information and enjoy our community...
did you swap the engine on your own? an, what i´m very interested in, is there a notedly difference regarding acceleration and top speed?
greetings
Alt 20.06.2010, 16:23   #16
Artemmka
All the job was done in service. But i everyday was looking how work goes. Especially, nothing hard, because i have 1 generation Xedos (without climat control, AC, immobilizer) and the KL 2.5 engine was from 626 1 generation too.
I pull accelerate on 3-rd gear about 2000-2500 rpm. and it runs good.
If you go on 1-st gear about 2000-2500 rpm, and then pull accelerate pedal, you will hear the noise of tire rubbing.
Top speed will be the same, because i have Xedos 6 2.0 gearbox.
I do not like to drive fast, 180 was maximum, once.
Artem (рус.Артём)
