Alt 11.12.2014, 13:56   #11
Belis
Zitat von aw_309 Beitrag anzeigen
So What to check? :-/
Battery from your Camera.
Because you have to want make a video for us
Alt 15.12.2014, 20:02   #12
aw_309
VIDEO - Idle rpm up and down
Ok here is the Video. The sound in the background is the radio in the beginning.
Now The VRIS is ok and no fautly codes. But still this weird rpm idle up and down.
Im planing to change the sparks.
http://youtu.be/A_UNOItmujM
Thanx! = )
Alt 15.12.2014, 20:53   #13
Belis
Sounds like Air-Intake problem.
Remove complete this guy
to have this in your hands and to take home and look accurate for fissure !
Strech every fin / rib !
if not help -> remove the throttle valve and make it clean ( idle bypass pipe )
if not help -> search with aliphatic volatile hydrogencarbonates for leaks (motor will do anything when you have leaks)
if not help -> change throttle valve potentiometer
if not help -> change the air mass flow meter
if not help -> change throttle valve completly
if not help -> Burn the xedos down
