Alt 31.03.2016, 16:52   #11
aw_309
Because ECU is changing timing!
So you need to tell ECU to go to std. setting.
I know i have to have a cable between ten and ground bout i thougth it was som other special cable! oki!
Alt 02.04.2016, 09:04   #12
hörnchenmeister
Did you have the problem with your KF. too?
Does the problem come with KL swap?
Alt 02.04.2016, 10:03   #13
aw_309
I had the vibration before also but not so much i think.
Yesterday the car started to sound like it didnt go on all cylinder :-/
When im starting it then after 10sec its bether.
Allso it feel week when im push the gaspedal and sometimes it will only go to 3000rpm even if push gaspedal. A litle stutturing also. Checked faultycode. Number 24!
Not easy problems for you to help me with.. Anyone comes to gothenburg this summer = )? Can listen!
I will change the fuel pump and the filter next week because that also is a problem.
I weent to a car dealer that had a Ford probe 2.5 v6 and that engine sounded so good. Mine doesnt not but i hope the time setting will make it better.
New video:
not all cylinder inte beginning of the video, first seconds.
https://www.youtube.com/watch?v=TeAiZv3eCTg
Geändert von aw_309 (02.04.2016 um 13:18 Uhr)
Alt 02.04.2016, 15:54   #14
hörnchenmeister
The most problems with such symptomes are in the ignition ore the vacuum system. When the KF had the same problem it could not be camshaft´s .
Please also check the cooling system, in the past there some guys which had bad idle because of unsealed coolant caps.
fault code 24 = Lamdasensor back Block, inversion error
this was mine, some years ago, the wining noise are the new bearings from timing belt.
https://www.youtube.com/watch?v=ko4_pKHaNlM
Alt 02.04.2016, 16:02   #15
aw_309
So the faulty code is bad lambda?
The engine feels "jumpy"
Alt 04.04.2016, 10:47   #16
aw_309
UPDATE!
Hello!
I checked the intake hose again and took it down and sealed it better with new tape. After that WOW! The engine respond really good and its more power now.
I gues that was the problem!
I will buy a used new intake hose!! Anyone as one for sale to me? = )
THANKS!
Alt 04.04.2016, 11:27   #17
hörnchenmeister
Hey nice to hear that.
I think you should buy a new one.
Rubber gets old... I know the price, but a used one could even be defect soon.
Alt 04.04.2016, 12:05   #18
zimbo_64
Look here : https://www.drive2.ru/l/5620324/
I do the same, both one from Moskvich 4121 for 3 Euro and replace it.
Alt 04.04.2016, 13:49   #19
hörnchenmeister
Super Sache. I LIKE
Alt 06.04.2016, 19:37   #20
aw_309
Thats cool if it 100% works! = )
Today i got some new problems. Jesus, this car is really testing me.
Faulty code 25!
So i know i have some problems with the fuel pump when its 1/2 tank its doesnt respond as it should but now i have full fuel tank and still problem.
So is it often the fuel regulator or the solenoid for the regulator?
Any thoughts?
Thanks again!
Anders
