Alt 12.03.2015, 20:38   #1
aw_309
Set the timing 10. Cant fint the mark! :-/
I want to check the timing is right but i can't fint the marking for the stroboskop lamp. Checked everywhere on the left side near the water pump and around.
Anyway to check that its 10 degrees without this mark??
Help please!
Alt 12.03.2015, 21:39   #2
The marking is locatet at the crankshaft, right behind the two belts.
Alt 12.03.2015, 21:50   #3
aw_309
Looked there also.. :-/ any picture?
Alt 13.03.2015, 07:11   #4
Hits:	762
Größe:	103,3 KB
Alt 14.03.2015, 08:22   #5
aw_309
Here is a picture of my engine..
Hits:	704
Größe:	230,8 KB
Alt 14.03.2015, 09:22   #6
neo303
Xedos 9 KL (2.5) '96
the v-belt is in bad shape (!) and you lost the part of the cover where the markings for the timing are - a part of the cambelt is not covered which could lead to serious damage!
Alt 14.03.2015, 10:06   #7
aw_309
Ah, so the mark is on the cover. : - /
Yes I know , I bought the car in this condition and recently received view that they have removed the lower part of the hood. Cheating Jobs . Guess there is lot of work to get a new cover ? Can I set the ignition without cover as long in some way ?
Thank you !
Alt 14.03.2015, 11:12   #8
neo303
you could create a mask with the markings on your own - if you can get hands on an original cover. but in that case you can install the cover right away too...
maybe Peter Willer can help you (www.xedos-shop.de - link is also on the righthand menu of this forum on the very bottom).
Alt 14.03.2015, 11:17   #9
aw_309
Is it same cover on Xedos 6 and 323f 2.0 v6? Both KF engine type
Alt 14.03.2015, 11:46   #10
neo303
not 100% sure, but i think so. K-engines in general are very similar!
