Zitat von gogboy
Im in the uk,so you think the oil is fine at the moment? maybe wait a few more miles? the colour and level are fine.
If the colour is good and you don't have problems with it, I think no need for a change now.
You can wait. But for sure a change now wouldn't be wrong! So its up to your choice.
Zitat von gogboy
also i have only ever put 5w 30 in all my Xedos put i have seen on here so many times to use 10W 40,even the mazda garage here says to use 5W 30,will there be much difference with using the 10W 40??
thanks again
I personally using 10W40 instead of the 5W30.
Because 5W30 is too low viscosity in my opinion and more expensive and not needed.
But its not wrong to use that one.
If I'm not wrong, Mazda (not the garage) is specifying 10W40 for the K-series engines.
I think your garage is advising 5W30 because this is now the common oil for Mazdas from all the 20xx years.
regards
