Alt 10.02.2016, 13:21   #1
aw_309
HELP! SHAFT left and right! what number?? :-/
Hello! I bought new SHAFT from website in germany and now it doesn't fit :-/
http://www.bildelaronline24.se/pascal/7177723
MAZDA here in sweden says that the orginal part number for my
XEDOS & 2.0 V6 AUTOMATIC is
LEFT: G0472560XB
RIGHT: G0472550XA
The problem is that is hard to find this part with that number and here i could only buy the front axel.. really expansiv!
So is there any other number i could use because now they have problem with
this i bought..
Anyone??
Alt 10.02.2016, 13:37   #2
Mazda 3 Fastback (2023)
There are (a lot of) different axle drive shafts for the Xedos 6, depending on its production date.
Please post the production date of your X6 (get it with http://www.xedos-community.de/infotool.php) or your VIN and I will have a look in the official parts catalogue.
Alt 10.02.2016, 13:42   #3
aw_309
JMZCA12B501203322
Typ: Xedos 6
Modell: CA41EAN
Seriennummer: 203322
Motor: 2.0i V6
Getriebe: 4-Gang Automatik
Lenkung: 2WS
Schiebedach: mit
Modelljahr: 1995
Außenfarbe: Coral silver mica (F6)
Innenfarbe: Off black (CA2)
Produktionsdatum: 27.09.1994
Produktionsort: Hofu (Japan)
Hergestellt für: Deutschland
THANX!!!
Alt 10.02.2016, 14:20   #4
Left: G047-25-60XA
Right: G047-25-50XA
But I can't find such a part in one of the spare parts shops...
Alt 10.02.2016, 14:31   #5
Found (but in Germany): click here
Alt 10.02.2016, 14:54   #6
aw_309
in mazda here in sweden they said:
LEFT : G0472560XB
RIGHT: G0472550XA
which of the Shafts in the shop has this?? = )
Alt 11.02.2016, 12:22   #7
I also phased the same issue with my Xedos 9.
The problem is, that Mazda changed the drive shafts during complete production several times.
If we are talking about the outer joint (wheel-side with ABS ring) the connection to the wheel-hub will most probably fit.
But I guess the connection to the drive shaft won't fit in your case.
Can you please confirm at which side your joint don't fit?
As you have already disasembled, please count the number of teeth of the drive-shaft.
The one you bought is designed for a drive shaft with 23 teeth.
Waiting for your reply...
