Hello!
Is it possible to lower there shoke in rpm?
After the engine swap from 2.0 to 2.5 the choke when the car is cold its to high in rpm i think (2000 rpm first 5secunds then 1700 rpm)
Should it be around 1300 rpm when its choked?
Thanks!
Are you talking about idle rpm?
If yes, have you:
- completelly cleaned the throttle valve (incl. disassembly of idle adjusting screw)?
- adjusted idle rpm after it as per instructions?
The main point is which diagnostic system and ECU you have.
I guess both of them are still from your X6 KF, right?
Then you need to check how to do it at X6.
But I gueass, that all (Xedos 6 & 9 and MX-6) will have this "TEN" pin at Diagnostic port.
