OK,
Test the TPS. Set bridge in TEN and GND when engine running. If the cooler-vents turn on, you have to set it.
TPS Throttle position sensor
http://www.probewiki.de/TPS
than you set the idle RPM to 650 with bridge in TEN and GND in diagnostic port
with the little screw on throttle body
After that you calibrate the ignition to 10° before OT. even with bridge in TEN and GND.
Also check Ignition cables and the right firing direction
